I got me a Winch!!
sak00
Brooksville, FL
I figured if I waited long enough, one would rear is ugly head one day and yesterday was the day. I got a PTO and everything from the radiator forward. I'm very excited. It needs some scrapping and some rust control, but its all pretty solid. This one came off of a M35A3 so it had all of the hydraulic equipment with it. I am going to strip the hydraulics off and go back to the PTO driveshaft. Anybody know what the hydraulics would be worth??
I now need a driveshaft and the levers that go into the cab. I think that is it. If I'm wrong please let me know. I'm a patient guy so time is on my side.
I will get the winch and bumper ready and put it on the truck when I get it painted. It will take me a couple of weeks, but then the deuce ought to look "BAD". Any other info you guys think I need to know, please let me know as I'm new to these winches. I plan to read the TM's on them in my spare time so that will help.
Any info would be apprecated.!!!
Yippee!!!!1
m16ty
210
Dickson,TN
If I was you I'd keep the hyd motor. You could run a pump off the PTO. Hyd winches are much more controlable than PTO winches. I'll take it if you don't want too much for it :wink: because I'm already adding a hyd pump for my dump.
Nonotagain
41
Parkville, MD
The best part about a hydraulic powered winch is that when it reaches the maximum working pressure it will stop on its own.
Mechanical winches will operate until they break something which in my opinion is not a good thing.
dc3coyote
19
Chattanooga TN
Keep the hydraulic..If my thinking is right with long enough hoses you can make a removable winch.. Just think about being able to move from the front to the rear mounting.
scooter01922
42
Newbury, MA
I'll gladly take the hyd setup from you as well, depending on how much its worth to ya. Need to put a winch back on the 108 and as it already has the hydros for the crane it should be crazy simple to rig up. Barring that could you snap some pics of the hyd motor and get the info from it?? Be nice to know what the mil uses so that IF i go that route i'll know that it should work. Or is could just find a regular winch like everyone else.:-D
sak00
Brooksville, FL
Well like I said, I have little knowledge about these things. I didn't think about running the hydro's with the pto. Although, I would still need a pump. According to what I've been told, the hydro's work off the tranny pump on the A3's. So I could either get a pump and put it on the engine. I don't really want to screw with that. Or find some kind of pump to hook up to the pto.
I'm looking for suggestions as to what to do.
Not that I'm looking to make a fortune off the hydro's, but in what ball park do you think their worth? I'm not looking for a bidding war. And I hate to put anyone on the spot.
wsucougarx
65
Washington State
My biggest suggestion is to strip that baby down, clean out the gunk, and replace all the seals before mounting it. Got my seal kit from OD Iron for a reasonable price.
wehring
25
Angleton, TX
coupler
Please post some pics of the device that is on the shaft of the winch. I mounted a 20,000# winch under the bed of my bobber and I need to power it. That coupler looks like the missing link because I have a PTO w/ rear hydro pump on my trans. All I need is the unit that converts hydro power to mechanical power at the winch.
Any part numbers or identification on the unit is appreciated.
Justin Wehring
979 997 3112
hoopsoft
Purcell, OK
I would try and find a way to get it working also, its a pain having to work the winch from inside the truck, be nice to have some levers on the outside.. of course now you need locking brakes like a wrecker and the cable snapping could kill you... hmm maybe nevermind.
Floridianson
2,439
Interlachen Fl.
I agree
Does not even have to hard mount if hung from chains and then hung on front or real shackles..
scooter01922
42
Newbury, MA
No idea what it would be worth, don't think i have seen anything like that offered for sale so it may be tough to figure that out. Certainly seems to be a market though. Just grab some specs and pics whatever you do.
m16ty
210
Dickson,TN
Like others have said, Please post the info off of the hyd. motor and maybe a pic of the coupling.
sak00
Brooksville, FL
OK, i took some more pictures this morning of what I got. The first pic is a bracket that I'm not sure I need. It might go with the hydraulic pump. Oh Crap, these pics didn't turn out right. Cell phones! I'll fire up the regular camera when I get home. Sorry
800summit
Soldotna, Alaska U.S.A.
If you have it out, Check the Drum oil seals. Long time sitting will dry up the seals .
you will have to remove the cable, and pull the winch apart. The job is easy, the parts are heavy:cry:
