I GUESS MY M1008'S Turbocharger is too small
Kaiser67M715
26
NH
Keep PSI under 10, and EGT under 1100F for safe operation. my 6.5 turbo runs 6-700F normal, when pushing uphill rises to 950-1000F. only 10psboost because my wategate opens too soon
EGT on turbo engine is normally hotter then NA, because you are compressing and Heating the incoming air. you can help reduce EGT with intercooler or meth injection, but overkill unless you are looking for max power.
Ilikemtb999
46
Denver, CO
The drive pressure is much lower with the hx35w than a stock 6.5 turbo which means more safe boost. I also ran 12 psi without any issues on my 6.2 with a gm-4 turbo. My EGT really never got much over 900* pre turbo.
Kaiser67M715
26
NH
yeah, I'm hoping to go to a boost regulated wastegate system, currently I'm running a mechanical spring pressure, and am fairly certian it opens way too soon, which allows overfueling, and that contributes to the higher EGT when pushing it. actually hope to upgrade to a HX35 myself this summer. I want to try and get 15psi boost safely.
