I have been advised to bypass Slave Plug resistor on firewall behind shroud
Riverbend
Cumming, Ga.
Before I jump into this, I would like other opinions onnit being a necessary mod or not, and if possible pictures of the steps to take to avoid trashing something I shouldn'd.
I am New to diesels and still rahter timid at attempting work never done or sure about proper steps. I know there are many experts gere and if someone would help this butterfly(pun intended) become a diesel dragon, it will be greatly appreciated.
I'd rather now damage my new to me M1009 which seems to be in great shape to me.CUCV FRONT.jpgCUCV REAR.jpg
319
Lieutenant
50
Michigan
That resistor is for the glow plugs. There is no resistor for the slave plug. Unless you're having issues, leave everything as is.
1,814
I can see how someone would have related the resistor with the slave. Here's what you have. I can't explain how it works as I'm electrically ignorant. The resistor on the firewall steps 24V down to 12V to operate the glow plugs. If 1 glow plug fails, it increases the juice to the other glowplugs and the start failing in short order. The more that fail, the higher the juice and the shorter the remaining ones last. The military did it this way so that even with dead batteries, it could be slave started. Moving the source of power off the resistor and to the 12V side of the harness eliminates the possible overcurrent but limits the slave starting when the batteries are really low. At least that's how it has been explained to me!
ralbelt
9
West Warwick, R.I.
Thats the way I understand it. Bypassed mine a few years back, it takes an extra 15-20 seconds for the wait light to go off but all works well.
scottladdy
CT
Glow Plug Resistor Bypass
Very sweet ride. Want to sell it? :-D
I recommend the bypass for civilian use. You can read a lot about the pros and cons if you search the CUCV forum. But, in short the military had to compromise on the design (what design isn't a set of compromises?) in order to allow a truck that might need to be started in a hurry to be jumped from a 24V NATO standard source. As was mentioned above, each GP that fails (they all eventually do) causes an increase in circuit voltage as the total load on the circuit is reduced. This causes the remaining GP's to see increased voltage, which is likely to hasten their demise.
If you do decide to perform the bypass, make sure to disconnect the negative cables on both batteries before starting work. Start with the front battery as that one is grounded to the vehicle frame. This is a must for pretty much all electrical repair work.
Some suggestions:
It is up to you as to whether or not you leave the resistor in place on the firewall. I chose to remove mine, and have them in storage in case I ever sell them to a "collector" that wants original. Keeping them in storage should slow down any further physical deterioration of the resistors. It also allowed me to treat the small amount of rust on the firewall while it was still surface rust.
If you leave the resistor mounted, I recommend removing the feed wire on the passenger side which connects to the 24 V buss. The feed wires are connected to the resistor by a very small stud/nut that can be removed. Some folks just cut the wire.
You can utilize the wire on the output side of the resistor. It should already be connected to the top of the relay. If you remove it from the resistor it is just the right size to connect up to the smaller stud on the diamond shaped junction just above the relay. This junction block is your 12 volt feed for the bulk of the truck. It is connected electrically to the positive terminal of the front battery, but physically to the negative terminal of the rear and passes through a fusible link running along the firewall.
While you are at it, clean ALL connections you can. Coat them with a small amount of dielectric grease to help reduce future corrosion. Make certain to clean as many grounds as you can!
Be prepared to replace the Glow Plug relay after the bypass. It seems fairly common that an old relay that has switched 24 volts cannot pass 12 volts well. My theory is that 24 volts causes increased arcing of the relay contacts. This creates additional deposits on the contacts which 24 volts can overcome.
Please let us know what you decide to do and how it turns out.
Vhyle
Clarksville, TN
Another thing to keep in mind... once you perform the mod, you may have a hard time starting the truck, because of corrosion and again the glow plug relay. With the resistor still operational, the current coming from the 24v side is enough to overcome this corrosion in the GP relay, making the truck able to start. Changing the relay's power source to 12v may not provide enough current to overcome this corrosion, so then the plugs won't get hot enough, and your truck will just turn over and over.
Best thing to do here is to replace the GP relay as well. NAPA's p/n is ST85, and they are readily available for a low cost. You CAN break open the relay and clean it yourself, if you choose to go that route. A quick search on the forums will lead you to some good instructions on doing so.
1,168
Please read the other members posts before posting repeat information.
Skinny
486
Portsmouth, NH
Sweet ride...welcome to SS!
Post up photos of your rig too!
The design isn't a compromise, it could have been solved using 24v glow plugs but that is another conversation. Unless you plan on running your rig with a military convoy and forsee dead batteries in your future, bypass that thing!
Riverbend
Cumming, Ga.
Skinny, I appreciate your help deciding
CUCV FRONT.jpgCUCV REAR.jpgOK, would you tell me what I need to do, can't afford a mistake.
I appreciate your help..
Here is my cute puppy:tank:
1,168
Has it occured to you that you are not the first person to ask this or want to do this modification?
Have you searched at all?
Sharecropper
952
Paris KY
I have bypassed my GP resistor.
Here's a few related questions, the answers for which are definitely not in the TM's. And yes, Mr. Doghead, I have searched and searched and searched to no avail.
Now that I do not have the resistor, does my slave port still work?
Can my truck still act as a donor truck and provide 24 volts through the port?
If my batteries were drained, can I still receive a jump start through the port?
Thanks in advance for the answers.
4,618
