I have joined the Goat herd
combat32
107
Booneville AR.
We be wrecker poor here;-)but that would have been my first choice. I pulled a lot of 113, and Bradley pacs with an 816 back in the day.
frank8003
4,989
Ft. Lauderdale, Florida
Tryin to hire someone to do some welding for me, it's like pulling teeth, can't find anyone who wants to work!
Find someone to replace baseboards, hand dig a hole, clean out a freezer, fix a roof leak, paint a shed, sandblast something, or rake the yard.
Seems everybody is "special" now and they don't have to work for food.
I do not understand......................
frank8003
4,989
post 17 is link to a new reprint of TM 9-2320-242-20. It is also available in the same reprint, used good condition, for 30 bucks, free shipping instead of 58 and shipping. Both dated 08021970. The PDF's here on SS are rather good copies.
I find that if one wants a particular picture from a TM then google all around that particular nomenclature to find some really clear pictures.
combat32
107
Booneville AR.
Wow just greasing all the zerks in the steering made a heck of difference in steering! I don't even have the boxes filled with grease yet.
combat32
107
Booneville AR.
More broke stuff
No wonder this truck was so hard to shift from 2 wheel to 6 wheel drive. Looks like someone did the old bailing wire fix, plus the heim joint is rusted solid.
m38inmaine
102
Maine USA
That is safety wire for the bolt, mine has the same thing. I had to replace my heim joint as well, you can see the part in my thread.
combat32
107
Booneville AR.
Well there is a good one on the parts truck believe it or not. Nice and shiny!
I did a lot of safety wire in my time, I was a Bradley Master Gunner and did all the gun services, whoever did that did a piss poor job.
Mark this is the engine gasket set I got from Red River
m38inmaine
102
Maine USA
That is the complete engine set, I will need one of those, good find. My parts carrier has provided many needed parts, glad it had the part you needed.
combat32
107
Booneville AR.
Got my radiator out today, it doesn't look too bad. I will know for sure when I get it cleaned and tested, my connection at the top that goes to the surge tank came off so will have to re-solder that. Installed some more parts from my parts motor that were missing on mine.
combat32
107
Booneville AR.
I also pulled the thermostat out of my parts motor and tested it, it works, it has no numbers on it but looks just like mkcoen's thermostat that he pulled from his so I think it is the right one.
m38inmaine
102
Maine USA
That's the right thermostat, tested mine as well, after mark's problems I tested mine right away. Great to see the progress pictures.
combat32
107
Booneville AR.
Everything disconnected on mine, she is ready to come out, those rear transmission mount bolts are a real@#%^*&!
Just waiting to get my Gantry Crane back from the welder.
mkcoen
382
Spring Branch, TX
Glad to see things are moving forward. I hated shelling out the money for the forklift but it did make things a lot easier.
Check your -20 under Power Plant Removal and Installation. On page 2-100 there is a picture in the upper left of the page showing the rear mounting bolts. In a caption inside the picture it says to Torque to 5545 LBS-FT! Now that had us going for a bit until you actually read step 26-6 which says to torque to 55-65 lbs-ft. Now if the caption had said 5565 I would have thought they just forgot the dash but don't know where they came up with 5545. Sure was hoping we didn't need a bigger wrench.
m38inmaine
102
Maine USA
Good progress, I plan on pulling my engine this weekend, borrowed my fil big jolly green tractor.
