I have to drop the fuel tank
Bobweb
163
Morganton, Georgia
have to clean out the tank, reached my
Hand in the bottom and it has about And inch of misc. slime/rust particles.
I have the TM, but just asking for any tips or tricks from someone who has done this before. Any thing to look out for? Also a way to test the in tank fuel pump to make sure it’s working properly.
any suggestions welcome,
Thanks-rob
cattlerepairman
3,533
NORTH (Canada)
If it is that cruddy, consider dropping it off at a tank and radiator shop that will boil it out. When it is spotless, coat the inside with one of the commercial tank lining products.
As for in tank pump: a gauge at the elbow above the tank; in tank pump should give around 5-7 psi.
If you wash the tank out yourself, protect your eyes. It's not a fun job.
Bubba also partially fills the tank with solvent, throws a chain in, puts the tank into the back of the pickup and drives bad roads really fast for a week.
Sent from my SM-G950W using Tapatalk
HDN
5,577
Finger Lakes Region, NY
It has to be easier than removing a fuel tank from my dad's M37. That thing was a bear to get in and out! At least if I have to pull the tank off my deuce I don't have to be under the truck the whole time :)
Bobweb
163
Morganton, Georgia
It doesn’t look too bad, like you say, it’s all open air.
Thanks for the advice cattlerepairman! I might try the bubba trick, all the radiator repair places close to me have closed. Nearest one is 100miles away.
1,827
Good suggestions on the chain and E85. My main tank on my M51A2 is full of crud but I have a new tank for it. The aux tank has unknown crud in it per the person that sold it to me. Sounds like a candidate for the chain and E85 There is one baffled end I don't think I can access unless I cut the top of the tank off.
fleetmech
405
Connecticut
Even with a really good cleaning, if you've got slime now make sure you dose your first few post cleaning fillups with biocide. Algae/ slime/ diesel bug (whatever you want to call it) is tenacious and good at hiding in tiny cracks and crevices. Change your filters too, before you get her going again.
Floridianson
2,538
Interlachen Fl.
What I have found there is a difference between a type of algae and using a biocide and Asphaltenes. Biocide did not cut through my Asphaltenes and had to use the FuelOx product for it. Asphaltenes are the tar or taffy stuff that stick to the bottom of the tank. Reach in and scrape up some if it is there and like said it is like taffy tar when you try and get it off your hand. Also I carry extra fuel filters as the stuff will move through the system when treated.
davidb56
1,239
Bonners Ferry Idaho
Ball bearings work the best. they can get by the "arch" in most baffles. you can even leave a few in there.
