steelandcanvas
- 88
- 48
- Southwestern Idaho
Probably when they stop acting like one.So, how long does someone have to be here to NOT be called a "newbie"???
I have not had time to work with my winch on my Deuce. But look what I found in place of my shear pin.
Tom,
I understand how it operates and how many men it takes to operate the truck. Friend I'm willing to bet I could educate you how how to operate this vehicle. In the conditions it was designed to be used.
First side note you don't have to read a TM but read the leaver on the winch with arrows. In gage/ disengage. Also there is the safety latch to keep it disengaged when not in use.
I bet 100 bucks on Tom.
On another side note I chuckle just a bit when someone comes up to me when I am in my 5 ton and they say I use to work on those. It's a Deuce right. I just have to chuckle and correct them.
Not really if you consider its half the winch of the oem.part of the reason i went electric with my winch choice, a bit more fire and forget in a stressful situation
I have a Series 18 on one end of my truck and a factory 10K lb PTO on the other end. I think I'm qualified to weigh in here.series 18 warn shouldn't be too much of a step back![]()
They both have good and bad points. The OEM winch can hold twice as much rope as the Warn 18 series and pull over 2,000 Ibs more. Now the electric can be operated with the engine off. No need to have two people "safely" run the winch. You can stand near by and watch what is happening, not stuck in the cab shouting is everything OK ! The electric winch is less complicated. No drivelines, or PTO's to go wrong or break. Just plug-in the cable and push the button.series 18 warn shouldn't be too much of a step back![]()
The Warn Severe Duty 18 series is far superior to the standard 4X4 winches out there. The electric winch needs far less mechanical devices to support them (Drivelines, PTO's, Shear Pins and such) . That is the reason the military went with them now instead of a mechanical winch. Yes all electric winches have a duty cycle, but unless your logging with it (which I have done) you don't need a 100% duty cycle winch. As far as having to replace the solenoids all the time, I owned an old Warn winch for over 30 years and used that poor old thing mercilessly and it never lost a solenoid or the motor, and I'm pretty sure this new motor will last far beyond 10 years. It's all in how you take care of your equipment. After a day out in the mud and crud I would "clean" everything including the winch. I made sure the electrical connections where good and tight and had some dielectric grease on them. Of course this new Warn series 18 doesn't have that concern since everything is fully incased in potting urethane. So for all the "naysayers" out there, the Warn electric winch is a viable option for our deuces. Personally I feel the Hydraulic style winch is the best of all, and the most costly. Maybe someday.I have a Series 18 on one end of my truck and a factory 10K lb PTO on the other end. I think I'm qualified to weigh in here.
The electric is perfectly fine if it's what you have, but it's not comparable to the PTO. Less cable, way less duty cycle, the reliability issues inherent to electric winches (i.e. a while of non-use and you get stuck solenoids, etc), etc. Not to mention cost of service/rebuild. Let's face it-with the factory winch, unless you blow it up (and in 11 years on SS I've seen maybe 3-5 people actually blow theirs up) your only cost is maybe $90 worth of seals every 25 years. Wait until you have to re-motor that series 18 in 10 years.
Obligatory proof:
View attachment 670595View attachment 670596View attachment 670597
View attachment 670598View attachment 670599View attachment 670600View attachment 670601View attachment 670602View attachment 670603
Not to mention that even though I got a screaming good deal on the winch, I'm still into the rear winch installation for what a factory take off front winch would cost.
Sorry for your frustration "rosco" , but sometimes conversations "evolve" . Actually this thread started as a "what" happened to my "70" year old designed winch on a "70" year old truck design. The only way to "improve" it would be to replace all the key components with modern steel ones which would be extremely expensive. There are several modern winches out there that could be adapted to fit this application but if your only interested in using the "original" type unit then your best bet would be to find a good used one elsewhere . So actually the way the conversation has evolved on this thread since the beginning over "4 years ago" is understandable.I believe "HIJACK" is the proper word here. The topic is & was about the repair, operation & maintenance of a PTO powered winch commonly found on the M35, a vehicle that is some 50 years old. Few would doubt that technology has marched on, and perhaps those who wish to extrol the virtues of the electric which could start a thread doing just that.
In the meantime, this old time vehicle could still use a little modern day understanding to help preserve some of its kind that still survive. Thank you, in case my frustration is obvious.
