I need a CUCV key and ignition Cyl.
acetomatoco
If you are a glutton for punishment, get the civvy cylinder and have the local locksmith rekey it for the CUCV code...just give him your cucv key, the new cylinder, and a few bux and like magic he will make it work...Get a good GM cylinder and it will last longer than the chinese or indian versions you may get at the auto parts store... ACE
455SD
piedmont ok
Re: RE: I need a CUCV key and ignition Cyl.
Good idea if I actually had a CUCV key to work with.
1,806
RE: Re: RE: I need a CUCV key and ignition Cyl.
Search the site for CUCV key code. When you get it, take it to a locksmith and you can have a CUCV key or 5.
1956_4x4
Crestview, Florida
455SD said:
Anyone have an extra they would be willing to part with?
I may have a set you can have within a couple of weeks. I'm going with a civilian set on my 1031 since there is too much stuff in the back to allow anyone with a CUCV key to drive it off. You're welcome to them once I change mine out.
Where are you in OK? I was stationed at Altus a few years ago.
Smitty
