i need a good trick to remove studs from hub of m35a2
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I have my hubs off to.flip them and i can't get the blasted studs out. Any pointers? Keep in mind i have no tool shop. Just a garage warrior. Lol
Have you un-bolted the hub from the brake drum? A good whack from a 5lb sledge worked on mine. Might want to put a lugnut(just a few turns) on to protect the threads.
VPed
276
Clint, TX
I used an air impact hammer with a punch bit. Short work but buggers up the L and R letters.
4,626
Lug nut on the stud to protect the thread. Liberal application of force from a 5lb sledge.
tie6044
42
Blaine, MN
I've done it literally a hundred times, I use a front lug nut and thread it on the stud so it is flush with the end of the stud. That way you hit the top of the stud and the nut equally. Make sure you hit it straight, I've had some bend if they were in there tight.
Artisan
227
CDA Idaho
PB Blaster, now sold at HomeDepot is REALLY GOOD STUFF.
It is not mandatory but if you squirt just a taste perhaps a week
before and every time your close to it, letting it seep in and work
will turm you into a believer.
It does not take a LOT! Just enough to wet the threads. You can
see the stuff disappear into the area you want lubricated! It works
much better than WD to "penetrating" . I think HomeDepot sells it
for less than 5 buck for an 11oz spray can. PB Blaster used with WD
once she starts to move is good trick. I did it today as a matter of FACT!
CLICK HERE
73m819
314
gainesville, ga.
Just smack them out with a BFH and replace them with NEW, the old ones are just that OLD, might even be OE, who knows how much they are stretched, If your putting BIG, OVERSIZE tires on, NEW studs would be the safest thing anyway.
DatGuyC
20
Essex, Maryland
I pushed mine out with a large bench vise and a socket on the back of the hub for room so the stud could get pushed out, not a single bent one. Beat them back in with the mini sledge.
