- 4,330
- 1,936
- 113
- Edmond, Oklahoma
Hey there folks,
I have a question for ya. When I removed my gauge from the M1009, I noticed that I didn't have the "ceramic" resistor on the back. I only had two wires attached to the gauge. I looked at the pic that was posted here earlier and wrapped my new resistor around the appropriate terminals. When I turned the key to the "on" position it pegged the gauge. Tested the terminals at the wire harness, 24v approx. with digital multimeter. Is it possible that this is a 24volt gauge? I understand from prior reading that is suppose to be a 12v. If it is, I guess that the gauge has gone bad, cause it will show approx. 24v prior to start up, will show 28v for a brief time after start up, then it will peg out. Any suggestions? New gauge? THANKS guyz!View attachment 581920View attachment 581921
Any idea if this is the same gauge used in the M1008? Mine is slightly different than the one you have pictured, as it has a little battery emblem bottom left and the word "volts" bottom right. It's an '85 truck. Thanks!I have good used gauges for $15 + USPS Priority Shipping. PM me if interested.
I used a Stewart Warner 82347 .That looks like a nice option. Does it fit the existing hole?
Yes 52 mm is about the same as the 2 1/16" hole. It will fit perfect.That looks like a nice option. Does it fit the existing hole?
Your using the stock gauge? It is a 24v gauge. If you have 12 volts to it, it's not going to register.Well, I put the resistor from Mouser in my stock voltmeter & it works but I'm confused. I haven't run the truck yet but when I switch the key on it get 25v on both sides of the resistor. The needle is at 12 o'clock. I thought the resistor was supposed to drop the voltage to 12v?
Not sure if anyone ever got back to you or not. But if you do the math, 24 Volts through a 300 Ohm resistor it comes out to 1.92 Watts. E=I x R (I=V/R), P=V x I. 24/300=.08 and 24 x .08 = 1.92. So, it might work for a while, but you really should be using a resistor rated for 5 Watts.Yeah I looked up that part number & saw the specs. Just wondering if the 1 watt resistor would work too.
