- 14,718
- 5,167
- 113
- Buchanan, GA
Strange that it blew inward like that...
The gasket that M35-tom sells is made by victor. According to VR literature, this part number was released in 2005. I suspect that this is the newest design available.I still have no idea which gasket is the new and which is the old, seems there isn't a straight answer for that one.![]()
Yes, I believe so. There are two o-rings in it. Mine were discolored and there was some AF in the oil. We changed it out and I drove it for a few months. Then in early November, when it cooled off around here I drove it and noticed what appeared to be some small amount of steam coming from the slobber tube.
I waited till it warmed up to worry about it because it is just too cold to fool with here. In Texas if it is below 50 it is called 'chilly.'
I changed the oil last week, started it a couple of times to check the pressuring of the radiator. Yesterday I noticed that even with the engine cold the pressure was causing a drip around the new radiator cap. Today I drove it to the garage to change the head gaskets, about four miles which allowed the engine to warm to the 200+ range. When we looked under the hood the slobber pipe was puffing like a locomotive. I pulled the dip stick and it puffed steam also.
I suspect the gaskets were weak, and perhaps leaking a bit earlier, but they finally gave it up now.
Your blow-by progressed, as in the issue got worse, or something else caused engine needing to be replaced? Or you don't know if the issues were related?http://www.steelsoldiers.com/showthread.php?130059-Blow-by-assessment-opinions-needed!
Had considerable blow-by for a long, long time. Progressed to major engine defect (not yet diagnosed).
Looking forward to your report. My air compressor is also noisy, and my main concern was if the air compressor is going bad, is the engine oil becoming contaminated with metal shavings from the air compressor?I forced forum member red into looking at the blow-by on my truck last Saturday. Re-checked the dip stick for oil color and content (still looked normal), and then added about 2 quarts of motor oil.
The engine still started easily and ran fine with all indicators (temp, air, oil) all in the normal. red also agreed that the exhaust looked and smelled normal. However, red's very first comment was how much louder my air compressor was than either the single or dual piston air compressors he has had. I've never been around, in person, other deuces when they've been running, or rather, when their air compressor has been running. As far as I recall, my air compressor has always sounded the way it has. But mine is audible even inside the cab when moving down the road.
After a 10-15 minute drive around town to get dinner, we inspected the blow-by out of the slobber port. It could be seen puffing a little more than back home, but after the air compressor shut off the amount of "exhaust looking" puffs appeared to steadily decrease.
Our current prognosis is that the air compressor is causing the puffing. It may be worn and allowing compressed air into the crankcase. This would explain the "puffing" out of the slobber port, the slight low reading on the dipstick (expelled vaporized oil), and why more puffing is seen when the oil is hot and more easily vaporized.
When I daily drain my air tanks, out of the "wet" air tank I would always see a drop or two of oil with the water, but never thought anything of it (not sure if this last part was right or wrong).
I am going to try replacing the air compressor and will report back findings.
That's a darn good question. I have only changed my oil 3 times in the 5 years I've owned it (I change it in the spring of the even numbered years). So last oil change was spring of last year (2014). I have not stuck my hand in the drained oil and felt around, but there has not been any metal shavings to speak of on the magnetic drain plug.Looking forward to your report. My air compressor is also noisy, and my main concern was if the air compressor is going bad, is the engine oil becoming contaminated with metal shavings from the air compressor?
Here's a poorly lit, and poorly aimed picture of my current air compressor. It sure appears a lot more oily than I've ever noticed before (in better light). It looks like oil is leaking around the air intake and even out through the air intake, and dripping down all over the base of the air compressor.
At initial inspection, this does seem to support that oil is getting past the piston ring and being pushed out on the intake stroke and then on the compression stroke air is getting blown past the piston ring into the crank case.
Also if the air intake is breathing oil this explains why I'm seeing oil in the "wet" air tank drain. Though, given the way the outside of this air compressor looks, I'm surprised I'm only seeing a couple drops of oil come out of the air tank.
