I think I need a camper like this...
It JUST has bigger tires, the frame and suspension is the same as the on road unit and will not withstand much off road use.
Eactly why I'd put the body of one on an M105 frame. Better yet, take the whole trailer, remove the axle and suspension, cut off the tongue and yoke, then mount that frame on top of the M105 frame with some urethane bushings to allow for flex and movement. Better still, crossmember the top of the M105 bed and set the teardrop on top and bolt it down, then you have a massive amount of storage under your sleep area. It might not be too pretty, but then if you want pretty, why would ya have a MV in the first place?
The possibilities are endless!
:grd:
