spankybear
- 981
- 93
- WA
When I drive down the road I hear the air dyer purging all of the time. About every 2 mins or so. I am in no way an expert on air systems on these trucks but let me tell you what I think I know. The air governor unloads the compressor when it get to the set pressure. That is PCHISS I hear from the air dryer. Then when the air drops below the low set point the governor kick the compressor back on line. This fills the wet tank . The outlet of the compressor goes through the air dryer. I think I have that right.
So I am not clear that when the compressor is unloaded is the supply line from the compressor open to atmosphere? I believe there is a check valve after the air dryer and before the wet tank?
The truck holds air over night but goes down a tad to like 80 PSI or so. I don't think this would be a large enough leak to keep the compressor cycling like it does. So I am thinking that a leak maybe before the service tanks.
With all of that said is the a common issue with leaks on the air system.
Can you troubleshoot with charging the from remembrance glad hand?
