I Want to replace my leaking IP, Or get it re-built.
mhb285
Paso Robles, Calif.
So I got my "replacement" IP from AMBAC this week. I've installed it yesterday & attached everything except the radiator. I'll install that tomorrow morning when I've got my soldier B.
I set up the timing myself. I've got everything correct (see pictures) except I don't see the "Red Tooth" in the HH window...... should I still fire it up tomorrow or did I screw something up...
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Sometimes the too5h isn't red, but it should still have the little score or "groove". It you can't see it, your 180* out of time.
mhb285
Paso Robles, Calif.
OK, I was able to save the gasket. Found the red tooth and got all the timing marks lined up. Needed 3x shots of cold start to get it started. It Smokes way more than it should. I can restart it for the 1st 5 min. with out a shot of cold start. After that needs a little shot to fire up. I think air is getting in some where? S#*T.........
I'm open to suggestions....
mhb285
Paso Robles, Calif.
Went thru all my fuel lines & connectors. They all look very good. Even replaced my air filter. Won't start cold with out a shot of cold start..... will start OK when still warm for about 15 min. After that needs cold start........ Looks like I got another lemon IP.
Sending email to AMBAC requesting a 3rd quality tested replacement.... Maybe the 3rd time is the charm :)....I'm now a expert on pulling & replacing IP's..
mhb285
Paso Robles, Calif.
Thanks Chris.
I pulled off the front valve cover and it was not on the compression stroke position with the harmonic balancer in the timing mark. I spun it around 1 complete turn and lined the harmonic balancer up again & it was right in the middle of the #1 cylinder compression stroke. The front IP timing mark was still dead on , but the rear "red" tooth was not visible. With the radiator removed, I pulled the IP timing cover off and spun the IP over till the "red" tooth was visible . With all the timing marks set & the radiator back in & re-filled It started 1st time and NO SMOKE!
Looking at the oil its kinda black , but with only 10 miles on it. Do you think that my IP timing mistake caused this? And should I change it out.
Mike Bogner
