KAILUAZ
- 0
- 0
- Tampa/St Pete
Throw me some ideas on how to get this texture effect using Gillespie paint, thanks!!
I agree....but I would roll the sand mixed paint on, then dry, then spray a top coat of your color of choice on to get an even finish. Otherwise you will see all the roll marks.gimpyrobb said:Sand in the paint.
No sand!!!!! It crushes and grinds as soon as you put pressure on it then comes right off making a mess you cant get rid of... use aluminum oxide!!! Order it from www.mscdirect.com (look under sand blasting supplies)
See how to do it here... http://www.steelsoldiers.com/index....tart=180&sid=3e5d47abd2f61fef93aa2fc6ec6595cf
You end up painting the surface two times but its well worth the effort to get a finish that WILL NOT EVER budge!!
