Identify these antenna parts?
papakb
1,196
San Jose, Ca
It's nomenclature is AB-558 and they were used primarily as the guard receiver antenna base on numerous military vehicles including the M151s. They use steel mast sections MS116, 117, and 118 or you can use the AT-1095 fiberglass upper mast section from the AS-1729 antennas.
MWMULES
352
DESOTO, KANSAS
The fiberglass base ones as pictured were mainly for armored use such as tanks and APC's but could also show up on a 151 instead of AB-15
CARNAC
The Envelope Please.
718
College Station, TX
Looks like Manfred. Yep, no doubt about it, I know Manfred and that's Manfred. Hope I identified him correctly.
papakb
1,196
San Jose, Ca
If your talking about the image you have in your first posting it's resin filled fiberglass and either mounts in a hole in the tank turret or in the bracket commonly called a sugar scoop or one of the flimsy aluminum brackets they hung on the back of the early HMMWV. On the 151 it would mount in a sugar scoop on the antenna pylon on one of the rear corners. The image MWMULES posted is the side mount bracket for the guard receiver in a 151 but that base will only accept the AB-15 antenna base pictured. The AB-15 is a 2 piece porcelain unit that screws apart, drops through a 2" hole in the bracket and then screws back together. It used the same MS-116, 117, and 118 masts or the AT-1095. The rubber flex section is the same as the one in the AB-558.
