IDIOT Light Problem with M1009
ONTOS66
Franklin, NJ
Here is a new one - for me anyway.
Yesterday when I parked the truck at home the idiot lights for oil and #1 alternator remained on after I turned off the ignition.
When the vehicle is running everything reads fine.
What happened and where do I start to correct this?
Thanks -
Preston
ida34
33
Dexter, MI
Sound like maybe your ignition switch is not going all the way off or is binding. If I remember right it is adjustable by the switch having oblong holes. You just loosen the nuts and move the switch back or forth until the lights are off when the lock cylinder is in the off position.
CCATLETT1984
Saint Clair Shores, MI
I agree with ida34 on the diagnosis, I am unsure if you need to pull the steering column apart to get to the switch though. I would disconnect the ground from the front battery until you are ready to fix this, otherwise it will drain your front battery.
225
edmonton ,alberta
drop the collumn...
i also believe it's adjustable...or it could be the lock cylinder is turning a bit,or starting to break.either way,the ign switch is pushed/pulled by a rod that runs from the lock cylinder.if it's not the cylinder,you don't have to remove the steering wheel...remove part of the kick plate just under the collumn,and access the bolts that hold the collumn up.
drop the collumn a bit,and you should be able to get to the one nut/stud and a screw to adjust.it's a fiddely job.you'll invent some new words,but it's not technical in any way.
