I have a 84cucv blazer, It will start but runs for a while and than shuts down, loses power to ignition system, I began to change the ignition switch to start with but the positioning of the ignition activation rod in respect to the on an off and accesory on the switch from what I can tell are backwards, off is on on is off from what I can tell, Is there a wiring diagram for the ignition switch that tell exactly which wire does what and which contacts need to be in what position to start and run and to show the proper display of the dummy lights on the dash so they work when the truck is started, Ive located which pin is hot on each plug but dont have a diagram to diagnose the problem any further, I'm not sure if the ignition switch was even the problem, took it apart and contacts didn't look arched or anything, they were a little worn though. I know which pin turns over the starter and which one activated the low pressure oil and overheat lights, Need a diagram to fix, see where everything goes. I would thank anyone who could help, have done just limited work on vehichles but am competent with electricity and mechanical things of that nature, any tips would be appreciated, maybe someone else has seen this before.
