Ignition problems
SUZ4x4
Brazil IN
I have a 84cucv blazer, It will start but runs for a while and than shuts down, loses power to ignition system, I began to change the ignition switch to start with but the positioning of the ignition activation rod in respect to the on an off and accesory on the switch from what I can tell are backwards, off is on on is off from what I can tell, Is there a wiring diagram for the ignition switch that tell exactly which wire does what and which contacts need to be in what position to start and run and to show the proper display of the dummy lights on the dash so they work when the truck is started, Ive located which pin is hot on each plug but dont have a diagram to diagnose the problem any further, I'm not sure if the ignition switch was even the problem, took it apart and contacts didn't look arched or anything, they were a little worn though. I know which pin turns over the starter and which one activated the low pressure oil and overheat lights, Need a diagram to fix, see where everything goes. I would thank anyone who could help, have done just limited work on vehichles but am competent with electricity and mechanical things of that nature, any tips would be appreciated, maybe someone else has seen this before.
Warthog
245
OKC, OK
The ignition switch is a standard GM switch. Autozone, Oreillys' and NAPA carry them.
Read the CUCV Wiki and the stickys in the CUCV forum.
The Military spent millions writing repair manauls. They where here on this site but are temporally offline. A fellow member has posted them. They are called CUCV Technical Manuals
http://www.steelsoldiers.com/cucv/61761-link-cucv-tms-free.html
Download them and study the first few pages of the troubleshooting section.It covers how to read thewiring diagrams
Also spend time reading the TM 9-2320-289-10 Operators Manual. It explains all the dash lights and how the truck works. Just like the Owners Manual in the Civlian world.
The diagrams are in the Appendix of the -20 and -34.
Warthog
245
OKC, OK
Once the engine is running, the only item that is required to keep it running is the PINK 12v feed wire to the injector pump. It controls the shutoff relay.
