I'm confused on tire sizes.
1 Patriot-of-many
69
Zimmerman MN
I need several new tires for my 939A2 series, They are all 14Rx20. Can I use 395/85R 20? I don't understand what the numbers mean, I understand the 20inch being the rim diameter, but the difference between 14 and 395/85 what is that?
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
To calculate the (nominal) outer diameter and overall tire width...
14.00R20: Diameter = (2 × 14" × 100% aspect ratio) + 20" = 48"
Width = 14"
395/85R20: Diameter = 2 × 395mm × 85% aspect ratio) + 20" = 46.4"
Width = 395mm (15.5")
The real size of a typical 395/85R20 is more like 46" tall and 15" wide.
Many of these 939 series trucks are running on 395s, with no issues AFAIK
wheelspinner
1,518
North Carolina - FINALLY !
I have 395s on my 923 but I changed all 6 because of the difference in height. It was a very worthwhile investment. 14-20s are going away. 395s will be available for decades. If you gotta swap any, might as well swap them all.
Brutacus
201
Marion, AR.
This should help some.
As I understand it, the main differences between the two are height and availability. 14.00r20 is 48" tall, and the 395 is 46.5" tall, 395's are more common now and 14.00's seem to be hard to find. 395's should fit on you rims, but still double check them to make sure.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
395's are more abundant and durable than the 14.00s. In the XZL brands they are near the same weight ratings. The 395s do get rid of the front axle wheel hop that the 14.00s have. Overall in width they are the same. 14.00s are getting harder to come by but we can get them brand new but you will pay for them with severe nosebleeds that you can buy two 395s for the cost of one 1400.
131
Poplarville, MS
Dumb question, but will the 395s work on an M35A2 with MRAP wheels(with adapters of course)?
I have a dozen MRAP wheels, the adapter plates and an M35A2 bit no tires.
simp5782
9,329
Mason, TN
Jeff Davis has some of the 395 Goodyear MTV tires at his place new. Or I can always bring some down to Memphis or when I get thru south Mississippi
Sent from my SM-G965U using Tapatalk
131
Poplarville, MS
Ill see what he has. Thanks for intel. I am just getting back to the deuce. Ive been preoccupied with the HMWWV.
simp5782
9,329
Mason, TN
Anyone use the 14-20's on a LMTV?
It has been talked about I know. Scott would know forsure but i think it has been done. They would fit just fine. and add about 6 to 8mph. and not as ungodly big as the 16.00s someone put on one. Only issue Some folks see is cost, but compared to what high speed gears cost. maybe itll help.
