spicergear
- 29
- 0
- Millerstown, PA
Someday...
http://www.vannattabros.com/adospics/31y.jpg
Sure makes the D7 I used to haul look small.spicergear said:
Yea $7,500 was heck of a deal i also swapped him a crated 903 I had for it. . .JasonS said:I followed your post on the stovebolt site. Sounds like a great project. A KT is a lot of engine. How much longer is it than an 855 cummins? You seem to have gotten one for a good price at $7500. Most of the ebay sellers ask that much for a core. I for one, would still be interested in hearing of your progress.
is it me or the view But that outer rear tire look's Bald. . .jeli said:Sure makes the D7 I used to haul look small.spicergear said:
Now lets not jump to conclusions, here... At this point there is no reason to assume that those are the desired end-results.DMgunn said:Steering shaft interference and front axle/driveshaft clearance problems can be very difficult to solve, if a safe and high-quality end result is desired.
dma251 said:Hmmm.... Any word yet on powering that front axle? Hurstssamx seems to be doing a little duckin' and dodgin' around that question.....
Seriously - Is there any reasonably straightforward way to accomplish that? It would seem to me to be a total waste to do a project like this and delete the front wheel drive...
My dad did the same engine trans plant i am. . . He how ever ran a completely different Gear box. . .DDoyle said:The M911 also used the 14.00-24 20-ply tire - although a different tread pattern, these should be available reasonably on the surplus market, should you chose to go that route.
A concern would be how many RPMs can the front axle and steering knuckle can stand. The axles under the ten ton are duplicates of the ones under the WWII-era Mack NO - which had a top speed of something like 32 MPH. Duplicate as in the same part numbers. I am certain that the Mack engineers did not envision the kinds of revolutions you do - and loosing a tire/wheel/hub/knuckle assembly would make for a very bad day - not only for you, but for anyone else on the road in a half-mile radius.
The weak link in the diesel ten ton is not the V8-300 Cummins, but the triple reduction front axle.
DD
I'm sure i would have to find a transfer case from an off road crane or some thing. . .DMgunn said:I am glad to hear that you know about letters and words. There are also these things called "grammar", "punctuation", and "spelling", none of which you have been able to use properly. You and your attitude are not going to make any friends here.
The person you are attempting to insult (if he would actually take you seriously) has built some of the highest-quality MV projects out there. You, on the other hand, have done nothing but talk. Yet you still haven't answered his question of "How"?
hurstssamx said:I answered your question right here ^ can't read ? or you just stupid dude ? I'm sure mommy din't teach you about reading but there are these thing's called letters you put them in centain oders and they from thing's called words whitch than in turn make sentences whitch form phrazes and or paragraph's. . . .But i'm sure you knew that ! ! !
Mike
