I'm pretty sure I've got the Vampire Issue.....
Gear Report
45
Nc
Can someone post a pic of the bypass pipe installed?
I bypassed my Tcase cooler this morning and used a section of hydraulic hose for the bypass and another to jump from one tcase cooler nipple to the other.
Not sure why everyone says to use a pipe instead of hydraulic hose for the actual bypass, but I figure I should probably make a bypass pipe just to be safe.
THANKS!
Action
1,564
East Tennessee
you can block of the T/C tubes any way you want as long as they are sealed up.....hose, rubber cap, etc.
Hose is just fine on the cooling lines, as long as it isn't kinked.
I have never heard of it being called a bypass pipe.
Gear Report
45
Nc
Yeah. I made up "bypass pipe". :)
I saw folks in other posts talk about bending a pipe to install for the bypass.
I made my bypass hose as long as would fit so it has a large radius. Will monitor for any signs that it wants to kink and make a pipe for the bypass if needed.
Tried to ad a picture, but it doesn't give me the option to submit after I pick the image to upload.
MarkM
CODE BROWN...It's all going to sh~t !
1,148
2,098
WOBURN. MA.
I am the latest victim of this but luckily I found the issue before tranny damage was done. Felt a slight slip when cold and I checked the fluid and found she was down three quarts. I bypassed the cooler in the transfer case using a bent up "U" shaped section of 3/8" brake line. Had to replace the air filter and found the only portal to get tranny fluid was the right front. Could have been a lot worse but still a PITA. I did try at first to just use hose (transmission line hose got for 17 bars) but I felt it may kink so I went with the brake line route.
Mark
Gear Report
45
Nc
Mark
I hope you are right.
Mine turned out to be a bad pickup tube oring above the transmission filter.
Gear Report
45
Nc
Same as mine. Turned out to be coming through vent line. Stopped only when I replaced the pickup oring. :)
Just suggesting that you keep an eye on it to be sure it really was vampire issue.
MarkM
1,148
2,098
WOBURN. MA.
Well it is good news as the leak was the transfer case cooler and bypassing it fixed the leak. Been driving the truck almost every day and having a blast.
Mark
StackJ
-2
SoCal
Read this with a great deal of interest. Does anyone have any photos of the "u-turn"?
Just a note: If I can remember (and sometimes I don't), Turbo400 trannies required a fluid check when in gear. I could be wrong and frequently am.
Dmljohnson
Miami
Ahhh this happen to me...I added a small cheap transmission cooler and mounted it externally, run 2 hose from the transmission line, to the transmission cooler and just make a u on the TC side...
Gear Report
45
Nc
Sorry, I am not clear on what you did.
You added a trans cooler to the trans?
Why?
There is a trans cooler on top of the radiator.
Dmljohnson
Miami
Why?
yes I know, I had it at the time, just looks good but serves no purpose, I know the TC used the transmission fluid to cool it, but was looking for a way to loop the transmission lines without kinking it, and I had a small cooler from a shifter cart that fit perfect under there.....lol ....I converted my 86 hmmwv to a 6.6 lml dmax so I don't have that set up any more...
Action
1,564
East Tennessee
If you didn't want to kink the hose, all you had to do was put a longer hose on....and you don't even need a hose on the t/c side, just plug (seal) the tubes.
Dmljohnson
Miami
So true....I'm one of those over thinkers, you know when something is simple ppl over think it.....it's was months after I realize it didn't make any sense, it made more sense putting it on the TC side with some kind of filter and pump....heres a pic of my 86 hmmwv with civilian doors...
319cssb
221
Easley SC
So do the NP 242 have this leak in the TC case cooler line happening less frequently? I am fairly sure , that I have a NP 242. It looks like what I can google up and I found a NP 218 earlier in this thread and what you can see doesn't look like mine. Also on my TC is some sensor or solenoid on the backside between fill and drain, which is not hooked up to anything. I think My TC has been replaced.
86humv
542
Texas
You have a 242....there's an early and late one...early has a 3 bolt tail shaft housing, late has 4 bolts.
There is a round I.D.plate facing aft that says what it is, and should have a date.
The updated ones sometimes had a blue band around one of the cooling tubes just outside the T/C.
Retiredwarhorses
4,602
Brentwood, Calif
The 242 had the vampire issue...the blue band on the inlet and outlet tube are the new type and fixed the issue.
your wire is your Tcase lock lamp switch...you need the name and harness to make it work.
319cssb
221
Easley SC
I wasn't looking forward to checking the transfer case level today.
But it looks ok.
So I'm pretty sure now, that I have a NP 242
Is this the blue band you talked about?
