Pull all lug nuts in the shop before you find out they do not
want to move in the field. Use a smidge of Anti-Seize on bolt only
during re-assembly. Torque to TM specs.
I have the standard issue lug-nut socket and solid bar handle. In addition
to that I have 2 more telescoping pieces of steel pipe that are
cut just as long as the storage boxes that when extended gives
me a good 7' or so of lever, just in case.
I upgraded the right rear gladhand w/ a tee and 3/8" QD
although on the too do list is to add a tank that you can
fill if needed on one truck.
I carry an air impact w/ socket and extension so after I break
things loose I can make quick work of it. I an have an electric
gun as well, the kind w/ the red Milwaukee tool colored handle
but the long body electric unit seem to hit harder I found
out after using 98G's.
Now that you have them extra tight you really will need to
lay into things to get them off. I have never had one beat me
using the telescoping pipe trick. Prop up the end and stand on it
AFTER YOU ARE POSATIVE WHICH WAY IT COMES OFF.
. Got all the seals on the way and the weather is getting nice so when it all shows up its game on.
