In need of a CUCV non-gear reduction starter.
jhyatt7
texas
My starter started dragging and then the ground wire (10 gauge) going from the front negative battery cable to the truck body burned up. A mechanic friend told me that the windings inside the starter have possible become damaged and is grounding out the system. Anyways, my CUCV M1009 is sitting in the garage not moving and I just got new tires. Does any one have a NON-Gear reduction starter I can purchase. Even if I have to replace the brushes, Im cool with that, I just don't know if the windings can be replaced and I definitely don't want a fire under the hood.aua
Warthog
227
OKC, OK
the gear reduction bracket should still be avaliable from the dealer
cliffyp
Brownsville, Texas
I was able to get the gear reduction bracket just a few months back when I was swapping starters. I kept the original starter and its bracket as a backup.
K9Vic
Fort Worth, TX
69
Hurst Texas
Get your oem one rebuilt.
+1 on the rebuilt. Look up Alternator / Starter rebuild in your yellow pages or Google. IF the rebuilder is not familiar with the CUCV 24 volt... just hand him the starter and give him a gentle reminder and he can get the parts and then install.
I think I went through 2 of the gear reduction starters in a year and finally gave up and went with the rebuild of an original one. Its been almost two years now on the rebuilt starter.
You may want to consider upgrading the cables. These trucks are old and have been through a lot!! The rebuilder will also have the ability to make cables specific to the length you want/need with the correct ends.
Third... keep your connections tight to the batteries.
Good Luck!
K
markg
hutto,tx
My starter started dragging and then the ground wire (10 gauge) going from the front negative battery cable to the truck body burned up.aua
if that cable gets hot and burns up you lost the the big ground at the back of the intake manifold by the fuel filter. tighten it up, you may not need a starter. thanks. mark
