3rdmdqm
- 101
- 43
- Woodbine Maryland
Need help. I have read thru most, if not all, of the threads on the in-tank pump, however none cover this specific question. I have removed the pump from the tank and cleaned it up. The metal braided wire goes up from the pump, up into and thru the bottom of the cover plate and attaches to the fuse assembly in the small box on top. The wire needs to be replaced or repaired, the insulation is brittle, cracked and exposed. However, I cannot figure out how to get the metal braided wire out of the threaded port in order to repair the wire. Does anyone know how this comes apart? The pump itself works, really would rather repair the wire than spend money on a new one if possible. Thanks.
