Banshee365
- 14
- 0
- Ocala, FL
Hey all! I've had a dead fuel pump that I think I bought from white owl. I accidentally left the power switch on which slowly killed the batteries. I think the pump slowly dying with the batteries burned it up. That's neither here nor there really. It's dead. I've ordered a new on from Olympic Controls to get the truck up and running again.
I wanted to see if someone could help me out with the wiring under the cap of their stock pump. I'm fairly sure the pump I pad top dollar for is Korean. There are no markings on the pump body at all and everything is soldered under the cap rather than screwed together. There is also a resistor or something between the fuse block and power connector. The man at Olympic said there shouldn't be a resistor there but I just wanted to make sure before I install the new pump. I'm planning to just unsolder the old stuff and find a screw that fits the fuse block and fasten it the way it should be.
Thanks so much for anyone that can run out and take a peek at there's for me!
-Kelly
-Kelly
