In tank pump failure, pics
JCKnife
46
Kentucky
The new pump is on the workbench, the bracket assembly needs a good wire-brush treatment, fair amount of corrosion. Plus very rainy today. I'll be running by the weekend. :)
(or maybe Monday at the latest...)
SWoods
Bridgewater, NH
I also just ordered a new in-tank pump from Olympic Controls for $225 including gaskets. Dave was a pleasure to do business with. The part number is 311-389-1.
JCKnife
46
Kentucky
Success! She is purring like a 40-year-old camo kitten.
But...did I mention it rained a lot while she wouldn't start? And did I mention that our other vehicles, parked next to her, are white?
I'm off to the car wash...
JCKnife
46
Kentucky
One more thing I noticed: the new pump is considerably quieter than the old one. I wonder if I didn't have a non-working pump all along, and just the IP suction was drawing fuel, and then when I went to 60%+ WMO the viscosity was too great for that...
Farmun
Ashland City, TN
Success! Got the new electric fuel pump installed and she's running, like a champ. Here's a couple of pictures for your viewing pleasure. Total cost, eh, about $75 for pump, fittings, and odds and ends...
Farmun
Ashland City, TN
Probably could have mounted it behind the frame rail, and it would have been a cleaner install. But I wanted it as close to the fuel as possible. Nothing that can't be changed later on down the line. For now I am running, and that was the main objective.
JCKnife
46
Kentucky
When I was planning to do the external pump I was thinking of using some kind of "project box" around it and painting it to match the truck. Both for protection and a neat appearance.
Katahdin
24
Scarborough, ME
Yuck. This is what I was greeted with when I pulled my pump this evening. I had no idea the screen and shims and fallen off, besides reading about the possibility in this thread.
Anybody else have this brown crud? At first I thought it was rust but its non-magnetic. Could it be cosmoline? I'm half tempted to cut access holes to the other baffles like Cranetruck did so I can cleanup those areas.
At least the crud cleans up pretty well. Glad I'm doing this before attempting to drive to the Maine Rally!
gimpyrobb
dumpsterlandingfromorbit!
27,786
761
Cincy Ohio
Algae from water in the fuel. Get a gallon of carb cleaner, dump it in, and slosh it around. Mine was in similar shape. If you can't find carb cleaner, Xylene works good too.
Katahdin
24
Scarborough, ME
Ok guys....I've confused myself....I went and diligently cleaned up the pump parts I found at the bottom of tank....went to put it back together....scratched my head.....looked at your pics again....
I've got a differently designed pump, and the parts to an old broken one, don't I? :cookoo:
Beerslayer
55
Tualatin, Oregon
Best. Fuel Pump Thread. Ever. Thanks everyone for your contributions. I haven't a fuel pump problem right now but it is the kind of thing that bites you when you least expect it. A lot of what I have seen here could be fixed with a field expedient repair in a pinch, and what I have learned by reading here would probably do the trick.
Farmun, for the sake of closing the loop, would you please post in this thread the part number and source for the pump you used? When someone is just looking for a part, the numbers ~really help~.
