Jakelc15
- 38
- 28
- Hanover Pa
102635 is a 0 button
Not a fan of BFH adjustments. Luckily, if you only install the front 2 of 3 lower bolts it can be installed at an angle and rotated into position. I used some permatex gasket goop to stick the gaskets to the block to ease the wrestling match. I had to install the cooler fully assembled. All the holes needed re-tapped thanks to the powder coat people not masking the holes. The air compressor hose I bought was too stiff to make the corner without kinking so I need to get something more flexible.Looks good jarhead1086! How well did the air to water after cooler fit into the cabs fire wall?
I got the intake from the junkyard and cleaned it and powder coated it. The cooler was brand new in a rebuild kit with all new gaskets. I tried without luck to get exhaust manifolds from the junkyard. They all had issues (cracks etc.) so I bought new aftermarket manifolds for 1/4 the price Cummins wanted. They came with new bolts and exhaust gaskets.Did you get the intake and exahust manifold from a donner engine?
I know there is at least 2 types of aftermarket exahust manifolds available. Do you remember which style you purchased?I got the intake from the junkyard and cleaned it and powder coated it. The cooler was brand new in a rebuild kit with all new gaskets. I tried without luck to get exhaust manifolds from the junkyard. They all had issues (cracks etc.) so I bought new aftermarket manifolds for 1/4 the price Cummins wanted. They came with new bolts and exhaust gaskets.
That is about what I paid and I think this is the same kit. My local guy had this in stock. I had to install in one piece after carefully getting the bolt spacing right by tapping them into each other. Barely cleared at the front. Mine fit tighter due to the ceramic.I got a used manifold but this is the same one but new.
http://www.agkits.com/cummins-nt855...ig-cam-i-ii-iii-exhaust-manifold-3801322.aspx
