Inexpensive Wheel Seal Installer
DHennon
Orlando, Fl
Here is my first stab at posting pictures and a tip on the site.
I just finished replacing all the steel and rubber brake lines, M/C, Air Pack, wheel cylinders, wheel seals and re-packed the bearings. Following the extensive, " how to replace the seals" thread, and the potential for catastrophic failure by not redoing the brake components, I decided to give it a go.
I read several comments about installing the wheel seals and was a bit shy about pounding on them with a brass drift pin to seat them.
I made a trip to the helpful hardware place and bought some 3" schedule 40 PVC pipe about 2 feet long, a 3" slip x slip coupling, a 3" slip x female adapter and a 3" PVC pipe plug. The assembled installer is pictured below.
I did not glue anything together.
The coupling is exactly the same size as the seal and when you slip the seal over the axle tube, followed by the installer, all you have to do is tap the plug in with a BFH and seat the seal. Worked like a charm and only cost about $6 bucks.
DHennon
Orlando, Fl
So sorry... I would not copy someone's elses idea intentionally or otherwise. Great minds just think alike. Since there are so many mambers with so many posts, and I was not flipping hubs, I would have not seen your post. Please accept my sincere apology.
gringeltaube
Staff Member
2,267
Montevideo/Uruguay
Don't worry, just make another one but using steel parts, not plastic.
Works better and you can claim it your's... :razz:
Make sure your tool comes to rest exactly where the red arrow points at...!
G.
Odyssey M
Colorado Springs, CO
I used this same method after checking out CARNAC's post (2 piece build). It worked great--both are good ideas. I think next time around, I would add the collar you have on yours. The 3" pipe by itself was a smidge off, but still very workable.:beer:
