Info needed with Turn signals
Jim Deggys
Alexandria, Louisiana
My front left and right flashers in my M35A3 do not work anymore, they don't even light up. The turn signal light on the selector stays solid and doesn't flash when I select left or right turns (it use to flash). The rear L/R turn lights light up but do not flash. I have to manually "flash" using the turn signal lever. Both front bulbs are good and I have just replaced the turn signal selector with a new one. Any suggestions?
1,178
Flasher unit
1,178
Also, check the ground wire at the flasher unit.
They get loose.
beastm35
plainfield ct
Hi guys I found the same problem on my m35a2 the wires that go to the turn signal switch have metal connectors if they touch each other they short I put liquid tape so they stay apart turn signals work fine try that..
jbayer
St. Aug., FL/ McGrady, NC
The turn signal unit grounds through its attachment to the steering column. The front turn signals ground through their mounting bolts. The mounts ground through the fender. The fender basically floats on springs, and flasher unit grounds through the fender also.
Check for continuity/high resistance from the light sockets to the frame.
rustystud
2,964
Woodinville, Washington
That's why you need to run a "dedicated" ground wire from the fender to the frame.
pjwest03
37
Vestal/NY
I generally try to coat the ground connections with NO-OX-ID. I also use a bit of it in the all the connectors. It's an anti-oxidant conductive grease. The antenna and broadcast guys swear by it. It's also a favorite in marine applications.
JDToumanian
14
Phelan, CA
I had this same problem, and it turned out to be a bad connection at the terminal block in the engine compartment, near the steering column.
cattlerepairman
3,340
NORTH (Canada)
If you decide you do have a bad flasher unit, please search for the threads detailing how to make one out of readily available components. The replacement military units are not terribly reliable...
1,178
Because that truck has air-blinkers...
