Info on Reo M45
Gu3
Tres Piedras, NM
New Guy here, I am looking for any info on an M45 that I just purchased. Hope this is the correct place.
Here is the tag info:
MFD by Reo Motors, Lansing Mich.
MFD date: 1954
Model: CH-D-54
SN: 130135
Wheel Base: 178"
Total length: 277"
Max towed load: 10,000 lbs
Pay load 10,000 lbs
Max speed: 60 mph
2 1/2 Ton 6x6 M-45 W/WN
Stock #: G2742-8358196
Inspected by: EDM
Painted numbers on hood: US Army 41241229
Gas engine
5 speed trans
Based on what I have read, It would seem this truck was issued with single tires, therefore the lable "2 1/2 ton". If I am correct, there were very few issued this way in 1954, built by REO MOTORS prior to Diomond T. buying them out.
Any info on this is greatly appreciated! Thanks!
Update:
pics tags and axle. Does it look like 2 1/2 ton? SAM_1485.jpgSAM_1486.jpgSAM_1483.jpg
Seems big.
They are 6 lug, but could they have still been 5 ton with 6 lugs in 1954?
MWMULES
349
DESOTO, KANSAS
Welcome to the site, pictures equal a 1000 words and some under the hood is a + as some M54's were Gas and other were changed to diesel. The manuals are in the forum and finding a local guy that has owned is a plus also.
Please upload Pic's to the site as links can die or have passwords.
Need pictures of data plates on dash also as what you posted above "2 1/2 Ton 6x6 M-45 W/WN" Means it's a Deuce not a 5T and a 45 not a 54.
If your wheels have 10 lugs it's 5T , wheels have 6 lugs = 2.5T
Gu3
Tres Piedras, NM
The 2 1/2 Ton 6x6 M-45 is printed on the tag, as well as 10,000 lb rating which seems to contradict.
Also Model CH-D-54 I was told indicates an M54.
I am new to these, so just trying to figure it out.
Thanks for the reply.
Squirt-Truck
Master Chief
163
Marietta, Georgia
I do not think REO ever built 5 tons. They were International, Diamond, Kaiser, and Mack, but then me's memory is not what it used to be.
NDT
6,476
Camp Wood/LC, TX
Reo built thousands of 2 1/2 ton M45 Chassis-cabs for special uses such as fire truck, chemical service bodies, etc. The M45 had 11.00-20 singles, and would have the rear hubs reversed from a dual rear tire truck. Edit: wrong info, should say 9.00-20 duals and no reversed hubs.
Gu3
Tres Piedras, NM
Thanks, good info. also what do you mean by rear hubs reversed? There is room for duals, and it was sold to me with another set of four to make it a dully. (Not that it means anything).
Gu3
Tres Piedras, NM
Ok, so is it labeled an M45, and has a 5 ton pay load with dual's and 2 1/2 ton pay load with singles, correct? Hence forth the model: CH-D-54 ?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
It is a M45 deuce and a half. The 10,000 payload is on highway (has nothing to do with duals). It is absolutely not a "5 ton". The CH-D-54 IIRC is related to the contract number.
