Information needed on Banks "power" setup
30
US
I was reading online that banks made an intercooled kit and bolted an allison the 6.5l TD. Does anyone have any info on this? I was thinking of using an allison behind my engine and am just curious as to if it can be done.
Thanks ~Reno
Sent from my SM-N960U using Tapatalk
TOBASH
3,055
Brooklyn, NY
Thanks ~Reno
AFAIK, they discontinued the project several years ago after making two test vehicles. Once AMG lost the contract, the banks project was killed.
30
US
I don’t think Banks sold any of those upgrades to Uncle.
Agreed I think it was just something they tested. I was just curious if anyone had heard if the allison was a good idea considering Banks had used it.
NDT
5,916
Camp Wood/LC, TX
HMMWVs have plenty of weak points but I never thought the 4L80E was one of them.
TOBASH
3,055
Brooklyn, NY
The Banks unit was meant to give the heavily armored 12K vehicles better acceleration without major changes to the drivetrain. I believe it was supposed to improve 0-60 times to get them to approach 30 seconds.
I can only assume an Allison transmission was used because of the increased horsepower coupled with 12K weight.
30
US
So in theory if more weight didnt matter and you had less hp could the allison be put behind a 6.2 and achieve good (for a humvee) mpg and maybe slightly faster acceleration?
TOBASH
3,055
Brooklyn, NY
If you go 700HP Duramax, Allison/Atlas tranny/trans case is a solid choice. For you to stay with a 6.2/6.5 n/a or 6.5 turbo, 4L80E or 700R4 is plenty. Why waste $$$ with an Allison?
With either 4 speed, you'll accelerate off the line just fine.
Remember, Banks was looking for a government contract. Adding an Allison to the HMMWV upgrade would have meant tens of millions of more profit. You should not try to compete with Uncle Sam, so you don't need an Allison.
FYI, Plan B in California modifies the Banks turbo to fit in the front right engine bay of HMMWV's. They will also charge you upwards of 6K to do so.
Retired War Horses frequently points out that 6.5 turbo's go for 2K.
Your call.
Best,
T
30
US
Your call.
Best,
T
If/when I change the engine it will be a 6.5l turbo. I was looking at tranny choices mostly for the reduction of engine rpms.
TOBASH
3,055
Brooklyn, NY
Your low end will get you off the line quicker and your high end will be reduced with either 4l80E or 700R4.
I'm going 700R4 as I don't want to run an electric tranny controller on my A1. Others will disagree. Toe mato, Tah Mahto.
Gear ratios available on Wikipedia if you want to review.
30
US
When you do your 700r4 what are you going to do for the torque converter lockup? I have considered this route aswell.
30
US
I have the bracket assembly.
Isnt that for the tv cable? Im just thinking that when you get to a certain speed you would want to torque converter to lock up to reduce engine rpms and so the tranny doesnt over heat. Altho this is all stuff ive read online
