I_Publius
- 3
- 18
- Prosper, TX
I searched in the TM 9–2 320–289–34 for instructions on how to replace the fuel supply line, but I’m having trouble finding reference to doing that.
Must you remove the intake manifold in order to remove and add a new fuel supply line?
Mice chewed through the fuel line and I need to replace it only. The injection pump is new and was working perfectly prior to these mice having their snack.
I am hoping there is a way to go in under the manifold to replace that line and that someone can coach me through what tool is needed to remove the fuel line from the IP connector perhaps point to the correct TM that shows how to do that only.
If it is not an option, I will follow the instructions and go through the entire process of replacing the manifold and all the gaskets again.
Thanks in advance.
Thanks in advance.
