Injection pump idle adjustment.
Mogman
10,571
Papalote, TX
No all the connections are on the schematics in the TMs how do you know you have the correct wire attach to the correct posts?
The main thing at this point did it idle normally with the return going to a bucket if it did it is the return if not it isn't
Mattguy
1,333
Highland, Indiana
Just tested again. Same with return hose disconnected. Same idle. Also if I remove rear connector it doesn't change anything. I may pull cover off to see if cold start solenoid is stuck open.
Mogman
10,571
Papalote, TX
It is just a solenoid, would make no difference except the coil of the 12V solenoid would burn up, it is ether on or off
Besides the civy top does not have Packard connectors
