dlayman21
- 0
- 0
- Big Spring, TX
Hello, I just bought an 84' m1008. Guy I bought it from said injection pump was bad (not sure if he meant going bad or was already bad). Truck would not start without a hint of starting fluid.....I know, I know. Once started it would do great, start back up with no problems. If it sat for several hours then it was back to starting fluid. I had been running around town for a few hours and it stalled at a stop sign, started back up but as soon as I hit the gas it would die. Changed filter and with some starting fluid it fired up and sat running for about 30 minutes and ran down the road about a mile then stalled out again. Lift pump has recently been replaced and is still pumping fluid when I cranked motor. I bleed fuel lines. Now it will start at about half pedal with white exhaust and when I release pedal it will die....Any ideas on what might be going on. Thanks in advance.
