Floridianson
- 2,511
- 113
- Interlachen Fl.
I was cracking open the injector lines to bleed air, some would make the engine stumble and drop rpm. Three i believe, had little effect.
This type of system should self clear the injectors with out cracking them but it does not hurt to try. Of course the cylinders that showed a drop in rpm is what we want to see. Did you by chance feel the exhaust ports right at the head when it was running to see if those cylinders not showing a drop were even getting hot?
