Injection pump questions.
1,827
So I got this engine! Its the new to me LDT-465-1C. Its been sitting for quite a spell without the steel lines from the injection pump to the injectors. Question is how deep does one think the water may have gotten in the pump? Considering trying to swap out the hydraulic head. Haven't tried to start it yet. Just curious. How difficult is th hydraulic head to replace?
1,827
Got it Bjorn. Is that similar to the later IP manual? I was looking at images at work this morning but my head kept hitting the steering wheel. Something about lack of sleep or something.
Dieselsmoke
CA/NV
If water did get into the pump the only thing it could get into would be the hydraulic head. The head is very simple to replace. Just get the gasket set from Saturn and you'll be good to go.
ken
27
Houston Texas
Kenny, there is a "star" weep hole plug on the side of the hyd head. A 7/16, 12 point socket will take it out. Try removing it and see if any water/fuel seeps out. If nothing comes out, or only fuel comes out. Try to start it. But if you get water/rusty water i would pull the head and make sure it's useable.
1,827
Well Ken, too late. I swapped all the parts that my LDT was missing, over from the LDS engine. I had cleaned out the head while on the injection pump and used some heat valve lubricant before putting on the injection lines. After considerable time bleeding the system, I got the engine running. Its hitting on all 6 and sounds pretty darned good. Have a few things I need to square away and then its going in the wrecker.
1,827
Yessir I sure do. It's still attached. Just need to install an PTO which is on the floor in the garage
