injection pump rebuild kit?
hklvette
Christiansburg, VA
Hi all,
I've been looking for a rebuild/ gasket kit for the LDT's injection pump. Saturn surplus appears to be out of stock, and I haven't been able to find them anywhere else. The IP is leaking like a sieve and with diesel at $4 I'd really like to get it fixed.
TIA,
nw42
Gadsden AL
Check with Clarke truck parts. They had some listed on Ebay under the title of M35A2 injector gasket kit.
BadMastard
Duvall, Wa.
Ok, I'll bite. Why would you get a complete gasket set when all you need is the three new O rings? (Insert Groucho Marx look here)
P.S. in a more serious note, what size are those three O rings? That seems like a good item to keep with the truck.....
hklvette
Christiansburg, VA
I'm getting the set because all of the seals are rock hard. If I'm going to be working on the IP at all, I'm going to make sure that not only does it keep fuel in, but keeps water and other junk out.
