Injection pump swap and timing question
galeo7171
Cumming, Ga
Quick and possible silly question. When I replaced my injection pump and set the timing to the factory timing marks, I had to really pull hard and hold the ip in place while I tightened it down. Should there have been that much tension in the pump when rotating it to set the timing?
galeo7171
Cumming, Ga
When I swapped pumps, I removed the whole original pump with the lines still connected (to make it easier to change out the injectors). I installed the lines on the new pump, and then installed the pump on the truck. The lines were hooked up to the IP at the time of installation, but not hooked up to the injectors.
Barrman
1,734
Giddings, Texas
Were the line tie downs at the valve covers on? Did you put on a new triangle shaped gasket between the pump and the block? Did you put anything on the gasket to make it stick better or be slippery?
Turn your old pump by hand. It is pretty easy to turn. Now, put a little sideways pressure on it and it gets a lot harder. Add in a possibly rough gasket surface, a drooping IP if the nuts are loose, lines maybe tied down and you with basically no leverage to move the pump. It can be hard to turn. Snap-On and Kent Moore both sold tools to help turn IP's way back when. Some web sites have suggested vasoline on the gasket to help do timing adjustments. Once you get it set, how much more do you plan to move it?
