Injector lines..R/R or repair?
chuck500cc
DFW Area
One of a hundred questions I have about my new M35A2C. I have a new leak around the injector pump and it appears to be injector line related. Do I try to do what it says in the PS mag. or do I replace? I guess it boils down to $$$. One of the lines is leaking at the injector and running down to the pump. But, the lines are leaking at the pump. BTW, all the lines are tight at the pump and injectors. How much is it to replace the lines from the injector pump to the injectors??? I do not know when the last time they were replaced.
Chuck XD Fan
1,164
Just replace 'em, they aren't expensive and it sounds like you have multiple leaks. Once you replace 'em, you won't have to do it again.
You wanna' be 500 miles from home and broken down? That's how I look at Deuce maintenance.
M543A2
15
Warsaw, Indiana
If the leaks at the fittings are not caused by cracked lines, the problem can be caused by someone over-tightening the nuts. This deforms the fitting on the end of the line to the point it will no longer seal. Good lines should only be tightened enough to stop leaking.
Regards Marti
rosco
32
Delta Junction, Alaska
Its not uncommon for injector lines to fatigue & fail/leak. If you locate the crack, they can be welded - to "get by"! If there are several leaks, as above stated, replace the works. However, one of the things that contributes to the failure/fatigue, is the vibration. On many engine types, the Manufactures often use small bar clips to support & tie the lines together, to relieve & cancel the vibration. The little clips are sometimes a pain & in the way, but they really work!
Lee in Alaska
3,182
Sometimes just losening and re tightening the line will stop the leak. Give that a try 1st, but, it is always good to have another set for just in case. As for the welding of the line. Might get you outa the woods, but it will break again, usually at the end of the weld. Remember, there is 15k and more going thru those lines. Also, the isolators are a must, without them, you will have leaking and broken lines constantly if you drive the truck alot
