oddshot
- 116
- 43
- Jasper, Georgia
The end of my injector pump shut off rod is broken off where the shut off cable attaches.
I need to take off the cover and see what I have to do to repair/replace the rod.
I check the manual (TM 9-2910-226-34 Injector Pump Manual) and on page 3-1 it indicates that I just remove the two screws holding the cover on and cover and gasket come off.
Is there anything else I should know about the removal and reinstall of this cover assembly?
Is anything else gonna fall out or jump out at me when I loosen those two screws?
Any internal hookups or adjustments to put it back together?
Once I have it off … I should be able to fashion some type of repair. I have a lathe, drill presses and other machinery to make whatever I need to repair this shaft/rod
I know that I’ve seen a thread on this procedure recently, I did a search but I can’t find it.
oddshot
oddshot
