Injectors: Front Vs. Rear
welldigger
Benton LA
If you are making oil, then diesel fuel is leaking past the fuel density compensator. By-pass fuel density compensator.
MHassett
There are several places that can leak fuel into the engine oil. The fdc if you have one (my truck doesn't). The HH plunger. The HH o rings. The fuel control rod o ring. Also, the booster pump seal can fail.
welldigger
Benton LA
If you haven't noticed the actual level raising then it probably isn't leaking in. My oil level got 3 or 4 quarts higher than full twice. Once when I first got the truck and I didn't know any better and then after I changed the oil the first time I noticed it. Which prompted me to fix it.
