slantflat
- 25
- 18
- Atlanta, GA
Hey everyone.
1973 AMGeneral M35A2C, White muli-fuel engine. When the power switch is off, the oil gauge reads 0. When I turn the power switch on, the needle jumps to 60. That's before cranking. With the engine running it stays at 60. Actually pegged past 60.
What's a good place to start looking for trouble? I've read about the sender being for a 60lb gauge and having a 120lb gauge and vice versa. I'm not sure that applies here, since the erroneous reading is the same whether the engine is running or not. Is this a common problem amongst Deuces?
This brings up sub-questions. Is it better to have a 60- or 120lb gauge, or does it matter? What would it have had originally? Where is the sending unit located on the engine?
If this is all in a TM could you point me to it? The big TM I have doesn't cover oil gauges. Hm. Thanks everyone.
