Csm Davis
- 403
- 83
- Hattiesburg, Mississippi
What would be a minimum pressure for it to atomize?
If you run methanol/ethanol in a multifuel you might need to make sure you have a new engine and a crane at the same time.if you plan to run alchohal you also have to consider material compatabilty like an e85 compatible high pressure fuel pump
a walbro high pressure pump could possibly handle it
http://treperformance.com/files/TRE345Flow.jpg
