74M35A2
- 315
- 83
- Livonia, MI
Thought I would post a pic of the planetary drive workings of a modern lightweight high efficiency heavy duty starter. The armature shaft is splined and sits in the middle. These starters weigh 28lbs, are dynamically computer balanced, and are O ring sealed. Developed to last a minimum of 50,000 starts. Performance guaranteed down to -40F.
Our stock starters are fairly robust. But these weigh half, are 1/3 smaller, pull 50 amps less continuous (200 amps less inrush current), and have very consistent performance in cold and hot situations. Everything is needle or ball bearing.
