toddm
- 0
- 0
- Pewaukee WI
I Finally installed the air-o-matic on my Duece, finished it up today. My truck obviously had this on it before because all of the holes were in the frame and inner fender and I found a regulator still attached stuffed inside the frame rail. You could still see where the steering cylinder attached to the tie rod. I did not install the new regulator which came with the kit. The worst part was getting the two bearing shields in place. I took it out for a ride and really notice a difference trying to park it in my driveway, also on corners and the bumps don't rattle the steering wheel as much. Well worth $765.
