roalcoal
- 1
- 18
- poplarville ms
They come out air up real close to what a springer seat is when you sit on the springer.What kind of suspension do those seats have? Edit...Let me clarify. How much LIFT/Drop does these seats have?
My seatbelts hooked to the seat themselves. I used some 3/8in angle iron i has laying around for bolting the seat thru the cab and into it. I then welded some angle iron from the front angle to the rear angle iron.How did you anchor the bases and seat belts?
If you have a 939 series there are three air fitting on the floor board next to the drivers seat. The fitting closest to the rear of the cab is a air supply.Where did y'all hook up your seat air bladders? I found constant air underneath on the frame, but would like something in the cab.
Do you mean the parking brake? Did you tee off it?If you have a 939 series there are three air fitting on the floor board next to the drivers seat. The fitting closest to the rear of the cab is a air supply.
Yes you can tee off the most rear fitting.Do you mean the parking brake? Did you tee off it?
Thanks. I used the constant air from the front axle engagement. I bypassed the low switch engagement so only my dash switch locks it in.Yes you can tee off the most rear fitting.
