Installing reverse lights
FloridaAKM
I used a set of 24v speaker lights that I got from the Mt Dora show, mounted them in the same place as the Op did. The wiring was 16 gauge belden shielded wire that I had lots of & a switch that has the red safety cover that you lift to operate the switch. The switch was mounted in an existing hole just left of the steering wheel. I pulled power from the heater fan as it was available. There is no indicator to show when the lights are on, but if the switch cover is up, you know your backup lights are on. Now, I can see to backup @ night & not bump into stuff in the yard or @ work!
tcruwithme
I think I'll also use Clint's idea for a switch panel. I have three rotary switches for convoy, wipers, and rear work lights. That's one more of Clint's ideas added to my to-do list!
As for the reverse lights, I did this same mod using instructions from the previously-mentioned thread that Peashooter and Clint authored. It worked great. Here are a couple photos of the actual lights. As you can see, I bought a set of rear light bracket corners that came from an A3 and put them onto my A2.
1) Have you seen this switch? Which number plugs are power going to lights and power coming in from truck?
2) Which power source/location would be best to run power from?
I know this post is 2+ years old, but for the next time someone finds it...........
Yes, I have seen that switch, it's the master power switch in every M35, M38A1, etc.
I believe in the deuce that the A and C circuits always have power and when the switch is armed, the B and D circuits get powered.
I think I will steal your idea for the switch panel clinto ! I much prefer the military "on off" switch then to a standard civilian switch.
I love these switches, they have the look and they have this real "tactile" pleasure........... they don't feel rinky dink. They are rated for 20A continuous, with a 75A inrush. I need a few more.
I love your truck.
