Group,
I have a drum with an electric water heater element installed for heating the oil, but never use it. I just pump it into the centrifical filter & run for sevear hours, then pump it into my storage tank until I need it.
So far I have not gone through the first tank of fuel in my Deuce, but several friends wioth Deuces have been running my oil (straight) without any problems. When I refuel my deuce, I plan on running 75% oil & 25% fuel.
I may need to heat the oil this winter when it gets cold to get it to flow through my filter setup. Time will tell. But i think the water heater element will work fine as long as it has oil surounding it to prevent it from overheating.
On my drum, I welded a bung about 5" up from the bottom of the drum. then screwed in a 2" or 3" pipe, comming out to a 90 deg. the water heater element is screwed into the bottom of the 90 deg, and the top leads to my filter through a reducer.
I have had some problems with my Dieselcraft filter (all self induced), and they have gone out of their way to see that my problems were fixed.
My oil storage tank has since been mounted on an M200A1 trailer, for ease of moving it around if necessary.
Laterrrrrr
Avn-Tech
