EastRidge
- 22
- 8
- Plymouth Wisconsin
Well, i haven't had my M37 8 months and had to have my wife tow me home.......
On our way into town for an "ice cream" run, the truck, sputtered twice. At 40 mph, died, cam back.....drove on died and came back. Went another 4 miles into town without a hiccup. I thought I say the gauges "flicker".
Got our order, and parked. Started for home, and it died on the street.
The engine cranks,but the gauges are dead, so no indication of spark.
Sitting and turning the ignition switch off and on....it would start, the die.
I was in the cab, switch was on, and the gauges came up, tried to start, then it fired but died immediately.
Towed it home, and while being towed I tried the ignition switch like 10x and the gauges came up....
Got home, gauges would come up with the switch turned on, started, and drive 20 feet, then died again.
I am assuming (hoping) it's the ignition switch being worn out and making intermittent contact.
Help on diagnosis, as well tips on testing the switch.
In the event it IS the ignition switch....what is the best alternative to a stock replacement at $95.00.....as this doesn't need to hold on to being original.
Thank you in advance....gave as much of the symptoms as I could.
