Scout
- 4
- 8
- Scottsville, NY
My M813 has a problem with the left turn signal working intermittently. The right signal and the 4-way flashers work, but the left is hit or miss. I went through all 4 corners and disconnected the harnesses and greased all the connections. Under the dash, there is what looks like a much larger version of the rubber boots at the other connections. It was hot, so I took it apart and cleaned up and greased the connection inside (what is this?)
If I put the signal lever in the left position and it does not work, sometimes moving the battery switch will make the signal start flashing.
It's done this for a while and I started to chase the problem down yesterday, but it seems like the left side was working reliably and the right was hit or miss at one point.
